Rear tank/swaybar
Discussion in '1960-1966' started by Rich 5150 69, Sep 11, 2012.
  1. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    I`m not a welder by trade, not even good at it, but mine have held, not pretty mind you, that is why we have grinders, once the bed is on cut the hole for the filler in the left rear corner next to the stake pocket, build a box from 6061 alum diamond plate that will lock, large enough for a bottle jack and wrench as well. Second pic are the rebuilt bed sill plates top sill done, bottom was being done at pic time.
  2. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Lookin good Rich!
    Did you install a vent on the tank or will you just be using a vented cap?
  3. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    I'm using a filler from a Geo prism, cap and all, I just shortened the height of it, the vent runs almost to the top with a relief baffle built in, I still have to drill a vent hole in the cap through the side.
    " The Hot Wrench "
    That looks good to me ! .
  5. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Pics of filler and vent baffle, also will need to change the fuel line some what I`m too close to the panhard bar, I`ll have to put a 90 at the tank move the line over about two inches before my verticle run to the inside frame rail.
    Holy crap another redo....:eek:
  6. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    We set the bed back on the frame rails tonight, tomorrow I will start to button everything up...:cool:
  7. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Well just got a few things left to do, build the box from T6061 T-6 alum to match the bed, and remove the old tank/fill hole...then I can start on cab stuff.
  8. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    One pic from the rear, you cannot see the tank at 10/15 foot back at 12 inches off the ground...so far I'm pleased with the outcome.
  9. Coach529
    Coach529 Member
    Jamestown, ND
    Great info, thanks!!
  10. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Started cleaning up some parts, using cheap white vinegar, took four days to clean off 50 years of rust, cost 1.93, and no elbo grease, just let it soak, not sure if it would remove grease...
  11. rhill
    rhill Member
    Dripping Springs, Texas
    That's good info right there!
  12. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Garage art....neon lit tailgate....
  13. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Awesome stuff Rich.
  14. steve
    steve Member
    Virginia
    Thats some clean steel frame
    Rich,
    That frame looks very clean! the work some of you guys do is amazing.
  15. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Thanks Steve, this is kinda like a second time around, originally did this truck 22 years ago, the milage/abuse shows.. :) ..LOL
  16. 66 Truck Drive
    66 Truck Drive Member
    Next to my bench at the shop, Oregon
    Great job on the tank and sway bar install! Sorry if I missed it..but where did you get the sway bar? Thanks. T.J. :)
  17. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Sway bar picked up at a thrift store....LOL, 10 bucks out the door, new, never been used, just had to buy links and build mounts for it.
  18. donnie s
    donnie s Member
    Ludington,Michigan
    Thanks Rich for all the useful info & pics. I`m not that far yet. I got my tank mocked up & got new axles ordered from Moser`s today. Getting ready to order the same "4 HD lowering rear springs you & lakeroadster used & probably an adjustable trac bar. Now researching the front disc conversions 5x4-3/4 bolt pattern. If it ever gets above 5 degrees here in Michigan, I`ll be able to blast & paint the frame!
  19. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Back to the bed on my truck, decided to revisit the rear bed sill issue, after much research fiquired out that the bed is from a 60 to 62, due to the spacing of the rear bed sill bolt locations and evidently John ( Lakeroadster ) has the same, whoda thunk we both had differant beds,....but what I don`t understand is why John`s bracket does not reach the frame...here`s a pic from Allen`s truck and sense I had drilled out all 9 spot welds, moved the brackets in and plugg welded them in they sit right on the holes in the frame, This was done about a week and a half ago, now the new issue is this new mod had impacted the level of the bed, one of two options, buildin spacers for the rest of bed mounts or cut down the rear bed sills by 5/8 of an inch.....ARRRGGGG....LOL, gotta love doing this.....!
  20. Lakeroadster
    Lakeroadster Member
    Central Colorado
    I cut the end of the frame off... had to in order to make room for the license plate bracket on the roll pan. Why, there should be lot's of room... well I installed the roll pan between the rear stepside fenders and not hanging off the back of the bed.
    And the bed on my truck... it's from a 67-72. One of the first things I ever did to the truck was remove the 67-72 fenders and steps and replaced them with the correct 55-65 style fenders.
    As for using spacers between the bed cross sills and the frame, I used wooden spacers on my truck to raise bed steps level with the bottom of the cab. But since you have a fleetside that's not an option... it will throw off the body lines of the cab vs. the bed.
    Wrong bed [​IMG]
    Cutting the frame [​IMG]
    Bed Spacers [​IMG]
    This is a photo of the rear bed support, it is not stock. I fabricated this mount during the rear frame changes when I did the frame mount gas tank. Close quarters back here due to the location of the modified roll pan.
