ol' chebby's how to tech.s
Discussion in '1947-1954' started by ol' chebby, Nov 19, 2012.
  1. ol' chebby
    Consolidating my How to articles here to make it more useable for the new (and old) guys.
    Feel free to add any other how tos from the forum.
    The mother of all threads....How to assemble and AD..
    https://talk.classicparts.com/threads/how-to-assemble-an-ad.9530/
    How to wire an AD...
    https://talk.classicparts.com/threads/how-to-wire-an-ad.9536/
    How to install a Trique latch kit...
    https://talk.classicparts.com/threads/how-to-install-trique-latch-kit.12010/
    How to rebuild rear cab mounts...
    https://talk.classicparts.com/threads/how-to-replace-rear-body-mounts.18006/
    How to wire a relay...
    https://talk.classicparts.com/threads/how-to-wire-a-relay-or-relays-are-your-friend.13783/
    How to change the ignition lock cylinder...
    https://talk.classicparts.com/threads/how-to-change-out-the-origional-ignition-lock-cylinder.12295/
    How to install bed wood...
    https://talk.classicparts.com/threads/installing-bed-wood.12180/
    How to run new brake lines...
    https://talk.classicparts.com/threads/how-to-run-new-brake-lines.12161/
    How to pinstripe your cab...
    https://talk.classicparts.com/threads/how-to-pinstripe-your-cab-for-us-common-folk.12124/
    How to rebuild vent windows...
    https://talk.classicparts.com/threads/vent-window-rebuild.10877/
    T bird IRS install....
    https://talk.classicparts.com/threads/new-rearend.9169/
    How to build a gas tank...
    https://talk.classicparts.com/threads/how-to-build-a-gas-tank.9177/
    How to shorten a steering colomn...
    https://talk.classicparts.com/threads/how-to-custom-fit-a-steering-column.7908/
    How to install fender welting...
    https://talk.classicparts.com/threads/how-to-install-fender-welting.18009/
    How to install wiper bezels...
    https://talk.classicparts.com/threads/how-to-install-wiper-bezels.18008/
    How to install rear/ corner windows...
    https://talk.classicparts.com/threads/how-to-install-rear-corner-windows.18007/
    How to instal hood anti rattle strip..
    https://talk.classicparts.com/threads/how-to-install-hood-anti-rattle-strip.18010/
    How to assemble front fenders...
    https://talk.classicparts.com/threads/how-to-assemble-front-fenders.18011/
    How to assemble doors...
    https://talk.classicparts.com/threads/how-to-assemble-doors.18012/
    How to hang the front clip...
    https://talk.classicparts.com/threads/how-to-hang-the-front-clip.18013/
    https://talk.classicparts.com/threads/how-to-rebuild-vent-windows.18014/
    How to install cowl vent rubber...
    https://talk.classicparts.com/threads/how-to-install-cowl-vent-rubber.18015/
    How to install windsheild rubber...
    https://talk.classicparts.com/threads/how-to-install-windsheild-rubber.18016/
  2. denisf
    denisf Member
    Colchester, CT/ Clermont, FL
    Thanks very helpful
    These are great!
  3. denisf
    denisf Member
    vent window external pivot point
    Russ thanks for the how to on the vent window. Silly question, how should one remove the pin in the pivot point on the outside of the window?
  4. ol' chebby
    drill it out carefully.
  5. denisf
    denisf Member
    thanks
    Thanks, just ordered new rivets. Denis
  6. ol' chebby
  7. ol' chebby
  8. 51 chevy pu
    51 chevy pu Member
    Lansdale, PA
    Thanks
    Thanks for all of your work on this. From all of us that thought, hey, it's a pick up, how complicated could it be?!?
  9. ol' chebby
    Its just a tractor with a body. Any farmer can rebuild it out in the field......
  10. vwnate1
    I Prefer :
    " It's an anvil with wheels " :rolleyes: .
  11. ol' chebby
    Bringing this back up to the top for the new guys.
  12. ol' chebby
    Nother refresher for the new guys...
  13. ronaldg
    ronaldg Member
    Lowering your truck
    Hey old cheby thanks for all the priceless information is it possible that you could show how you lowerd your truck i am considering doing that and would like some information i am sure the others would also thanks again.
  14. ol' chebby
    Fatman superlow IRS with 2" spindles and air ride. Rear is a 95 T bird IRS welded up as high in the frame as possible to avoid cutting the bed floor, also with air ride.
  15. ol' chebby
    Top again for the newbies....
  16. sberman
    sberman Member
    wow lots of good info here
    thanks for your hard work
  17. Ricos54
    Ricos54 Member
    CA
    That was great info and will help me through my build, so thank you :)
    Rico
  18. Zig
    Russ is like that~ Not bad, for an artist...
    He's even got a link on pin striping, just in case you might feel lucky.
  19. ol' chebby
    I try to bring it to the top every now and again for the new guys.
    You can subscribe to this thread to make it easier to find.
  20. Kens 50 PU
    Better yet, let's convince our awesome host to make it a "sticky"! This is too good a resource to get lost every 3-4 weeks. What do you guys say? Should this be a "sticky" and mandatory reading for all newbs? My vote is cast! Thanks Russ!
